try to build a CR 750
Page 1 of 6 1, 2, 3, 4, 5, 6  Next
Post  silverCR750 on Sun 19 Jul - 2:02
Hi there,
I just bought me a CB 750
Itīs a beauty......
I would like to rty and build me a CR 750. But then with the parts I can afford.
Iīll keep you here posted.
Hereby a few picīs so far.
By silvercr750 at 2009-07-18
By silvercr750 at 2009-07-23
silverCR750
View user profile http://www.Racingteamtwello.nl
Re: try to build a CR 750
Post  silverCR750 on Sun 19 Jul - 2:06
Today i removed all the brackets on the frame.
It safes me at least 2 kg.
The frame now weights only 13 Kg.
silverCR750
Post  gitarsolo on Sun 19 Jul - 9:21
Very Happy good luck for your awesome project...i'm New Kid on The Block (NKOTB)..plz upload big picture. Shocked
gitarsolo
Post  silverCR750 on Sun 19 Jul - 12:35
I'll try to post bigger pic's.
Just bought me a second bike and parts.
For the project, the wheelbase has to change.
1492 mm is far to long.
This bike should have a 1420 wheelbase.
For this reason I need to shorten it by 70mm
40 mm from the "achterbrug"(what is the english for this part?)
And 30mm by changing the forkangle.
Anyone ever did this before?
Here is a pic of the engine and carb's.
silverCR750
Post  Ton Up Boy on Sun 19 Jul - 12:39
There is a guy , near Rotterdam , who obtained an original CR750 some years ago. He wasn't aware of this.
And when he got wisphered in, he started to restored for his son . being a Cafe-racer on the way,hahaha.
As he is a fanatic Norton pilot, he won't be seen on a rare Honda. Evil or Very Mad
Lots of luck with your project
Ton Up Boy
View user profile http://www.roadrocketclub.nl
Post  silverCR750 on Sun 19 Jul - 23:44
Thanx Ton up Boy,
I wishI had bought a original CR 750.............
Well today the first step is set toward a shorter Wheelbase.
I cut out 4 cm from the back of the rear.
This will be welded together again.
By silvercr750, shot with DSC-T1 at 2009-07-19
silverCR750
Post  marc on Mon 20 Jul - 10:08
Nice your off with a good start!!
I'm going to follow this project for sure!! Twisted Evil
Post  Hofman on Mon 20 Jul - 10:27
Whoh, nice indeed.
Can't wait to see all your modifications! First pictures are looking promising!
Good luck!
Post  silverCR750 on Thu 23 Jul - 21:49
Hey there,
Just bought me another CB 750 with some nice item on it.
Koni rear shocks
4 nice open airfilters
spare engine
alu triple tree
silverCR750
Post  Hofman on Fri 24 Jul - 10:24
The modification on the swingarm looks very interesting. Will the results be good if you only adjust the swingarm and not the angle in front?
Keep us updated how you weld the swingarm back together. This looks like an intersting thing for me to Very Happy
Post  silverCR750 on Fri 24 Jul - 21:44
Hey,
You're right, but I'm also changing the frontfork angle by 2 Gr.
This way the wheelbase of the bike will be more like today's superbikes.
Hope to weld the swingarm this weekend and know how to change the front angle.
you'll be posted.
silverCR750
Post  marc on Mon 27 Jul - 12:29
And, any succes?
Post  silverCR750 on Mon 27 Jul - 18:27
oh well it isn't welded all over but in place.
Need to change the angle of the frontfork so that the fronttyre comes back 3 - 4 cm.
This way the angle changes from 27 to 24 degrees. More racy.
I'm gonna get me my second bike now.
silverCR750
Post  Toecutter on Wed 29 Jul - 20:11
Thats alot of cleaning there to do. But hey Rome wasnt build ina day either , rite ?
new Beauty
Post  silverCR750 on Fri 31 Jul - 20:21
Hi there,
Picked up my second CB 750.
It's a beauty also called a snotter.
But she has some items I really like.
Koni rear shocks
alu intakes
boxed swingarm
And that's about it.
OHHHH and a nice complete engine.
Some work to do but it's all for fun.
If anyone needs some other parts please notify me
silverCR750
more parts
Post  silverCR750 on Mon 3 Aug - 23:25
Hi there.
My second bike is almost in parts now.
Only the engine and frontfork are in place.
I'm bussy cleaning al the parts witch cost me a lots of time.
I noticed there are 2 kinds of triple-trees.
1 is upper-tree is higher and the forklegs come further forward.
The other is flat and hereby the legs are nearer to the frame.
The new clipons are in the house.
They are Magura and aluminium.
keep you posted.
By silvercr750, shot with Canon PowerShot A460 at 2010-01-10
By silvercr750, shot with DSC-T1 at 2009-08-03
silverCR750
Post  silverCR750 on Sun 9 Aug - 21:40
Hi there,
Only bussy with small parts for now.
Cleaned many parts and traded a few boxes of my parts for a few new parts.
Front hub
Oilfilter screw
Yesterday I took apart the carburateurs en cleaned all the sand and oil of them.
Today I removed a lot of material from the upper triple-tree.
Tomorrow I'll weigh them to see witch one will be used in the bike.
Keep you posted.
silverCR750
Post  Toecutter on Mon 10 Aug - 9:53
alrite keep it up dude !
Post  silverCR750 on Thu 13 Aug - 23:08
Lots off work butt little to see.
That's what I like in a bikebuild.
Small details that make the diverence with standard bikes.
Parts that will only be seen by other people who know what it is to make a personal caferacer.
I like several bikes in the forum and think about the time putts into it.
see you.
silverCR750
Post  Gss on Fri 14 Aug - 9:31
Looking good ! cheers
Post  silverCR750 on Sat 15 Aug - 18:44
Today I build in an engine for measering the exhaust, rear shocks and frame.
Just for the picture I also put in the frontfork, frontdisks and clip-ons. :)
The frontdisk weigh about 6 kilo a peace. I think they will be changed for some modern and much lighter ones.
Now I can fit in the exhaust and see where the rearshock's must be placed.
The frame will be 1 centimeter lower on the front than on the back.
Rearshocks are 4 cm to short so a solution must be found here.
In this set-up there is 23 centimeter groundclearance. Original is about17??
All inn All a lot to think about in the coming days.
silverCR750
Post  silverCR750 on Fri 21 Aug - 0:11
Hi there.
Lots off time changing the looks of the enginecovers.
By silvercr750, shot with DSC-T1 at 2009-08-20
silverCR750
Post  marc on Sun 23 Aug - 19:25
Looking in the good direction! Very Happy
Keep us updated!! Cool
Post  silverCR750 on Tue 25 Aug - 23:19
Hi there,
Been to the races at Assen this weekend.
But also breaking my mind how to solve some problems.
Today I welded the rearfork and exhaust pipes.
Bought a lighter rearaxle and found what frontdisks cam be used on the fronthub.
still going on but not to much to see yet.
see you
DSC-T1 at 2009-08-25
silverCR750
Post  silverCR750 on Tue 25 Aug - 23:24
silverCR750
