try to build a CR 750
Page 6 of 6 Previous  1, 2, 3, 4, 5, 6
Re: try to build a CR 750
Post  silverCR750 on Tue 6 Dec - 1:31
and another one
By silvercr750 at 2011-12-05
silverCR750
View user profile http://www.Racingteamtwello.nl
Post  gsb on Sat 11 Feb - 23:08
Hi!
Another question about brakes- Model of rotor used ? ,and have your forks standard spacing ,what is with spoke clearing with used caliper how thick is rear side of caliper ?
Thanks GSB
gsb
Post  silverCR750 on Sun 19 Feb - 0:59
Sorry GSb
For my late anwser.
The rotors used are from a Yamaha FZR1000. But also from an Aprilia RSV, RS125 and Ducati will fit.
You will need homemade spacers to fit the rotors to the calipers.
The calipers used are from a Honda Blackbird. These are 3 piston calipers so the rear is quite flat.
This way there is no problem with the spokes.
Hope to have helped you a little with this.
see you
Coos
silverCR750
Post  gsb on Mon 20 Feb - 22:19
hi !
Thanks for info ,I will omit custom hub in my build .Calipers have 2 banjo bolts each -how conect you calipers to brake pump ? scratch
Thanks gsb
gsb
Post  silverCR750 on Mon 20 Feb - 23:15
I will have to connect one of the banjo bolts from the brakeline to the calipers and the second one with a double banjo to the other.
This is something I'll have to figure out.
A double brakehose over the frontwheel is also a possibility.
W'll see
regards
silverCR750
Post  silverCR750 on Sun 4 Nov - 21:14
hi there.
Time is going by but I'm still building on the bike.
In the meanwhile lots of small parts are made and put on the bike.
Like the rearbrake
silverCR750
Post  silverCR750 on Sun 4 Nov - 21:16
I've put on the tank, seat and fearing to see how thing look on the bike
I like it
silverCR750
Exhausts
Post  MadTrapper on Tue 12 Feb - 4:59
Just wondering where you sourced your exhausts. I am thinking about Dave Swarbricks silenced setup but if you have a better source?
MadTrapper
Post  razzpoutin on Tue 12 Feb - 12:08
sweet,cant wait to see the paint on that beauty!
razzpoutin
Post  marc 63 on Fri 22 Feb - 21:06
I love it. Really great looks on your bike.
marc 63
Post  suzukiac50 on Mon 25 Feb - 14:07
Can't wait to see how this bike will look like!! :-)
suzukiac50
Post  marc 63 on Fri 22 Mar - 18:27
silverCR750 wrote:I've put on the tank, seat and fearing to see how thing look on the bike
I like it
you're not alone . Very Happy Very good looking so far .
marc 63
Post  Rocker on Fri 22 Mar - 22:35
silverCR750 wrote:And after a few weeks of hard work from Cor, this is het result.
Thank you Cor
By silvercr750 at 2011-11-05
Great project! Congratz on the bike so far!
And nice job on the exhausts! One question though: did your friend build a complete exhaust line? I was wandering if you use balance pipes between the 4 different exhaust pipes and where did you place them? If you are building a racer and looking for the performance, balance pipes and there position are important...
Just a small remark Wink
Looking forward to the finished bike!
Rocker
