regards from the lowlands
Post  mille108 on Tue 27 Oct - 23:36
hi..
It started out life in 1993 like this
i bought it like this
And slowly it evolved into this
The rear wheel is a cut down 6inch aprilia rim (now 5,7 inch) for perfect alignment..you can see the weld go all the way around
Headstock
Exhaust
Further modifications
Removed injection system in favour of 42mm flatslide carb's
Digital ignition
changed the headstock and made the steering angle 2 degrees steeper
Home made exhaust system.
Honda RS125 seat unit
home made rear subframe(from a bicycle front fork)
Wrinkle paint.
Started with a RSV factory ohlins front end..now 50mm Marzocchi with bespoke radial brake mounts
Radial duc999 master cylinder
moto spezial hydraulic clutch
Michelin Power one semi slicks
Ural headlight assy
Digital speedo
ect ect
still to come..big aluminium swingarm
and lots more
some u tube videos
Any questions...just ask...
mille108
Re: regards from the lowlands
Post  andreas on Tue 27 Oct - 23:47
Hi Mille,
wellcome here, saw your bike this year in Achteveld - this is "hightec" on old "Italienbella" . Respect,
this is no BlackandDecker work !! Really a great ride and i know the sound.
What´s your next project - can`t believe that this will be the "one and only" for a man who made this quality craftmanship.
Post  mille108 on Tue 27 Oct - 23:59
andreas wrote:Hi Mille,
thanks Andreas
I got alot of thumbs up for the sound.. loud
This one is not finished yet(if ever)
But i really like the 180 degrees laverda jota engine.. and im a big fan of good handling bikes..so the mix beween old and new will always be present in my projects..
In my spare time i luv to ride the track on my RSV
After all the mod's the bike brakes and turns like a modern supersport..so lots of local heroes already have eaten the dust of the old guzzi.. the look on their faces..priceless
mille108
Post  650zed on Wed 28 Oct - 11:45
Welcome to the forum!!
Post  Wallace on Thu 29 Oct - 0:56
Hi Mille and welcome to the forum. Awesome Guzzi.
Post  kornfed on Thu 29 Oct - 1:08
Great bike. I saw it in Achterveld too.
Very special painteffect.
welcome
Post  Toecutter on Sun 1 Nov - 19:11
Welcome man ! Brutal Guzzi !!
Post  mille108 on Sun 11 Jul - 14:37
mille108
