Honda CB750 K2 new project
Page 1 of 3 1, 2, 3  Next
Post  kornfed on Thu 31 Dec - 18:05
2010 start for me with a new project.
It's a 1972 Honda CB750/ As you can see there's a lot of work to do.
I keep you guys informed of the progress.
Re: Honda CB750 K2 new project
Post  andreas on Thu 31 Dec - 19:11
Hi Kornfed - the basic looks good - sure alot to do - but what happen with your other xs750?
Post  CJ on Thu 31 Dec - 19:36
Nice bike!
Like the tank!
Don't get me wrong, but ity seems to me the amound of work isn't that much.
I mean your frame, wheels, engine, front end etc looks OK.
Maybe some attention, but no whole restauration.
Anyway: VERY NICE BIKE!
Where did you get it?
Post  kornfed on Thu 31 Dec - 19:45
andreas wrote:Hi Kornfed - the basic looks good - sure alot to do - but what happen with your other xs750?
Uhmm.... This is my other XS750 Very Happy
I made a trade whith the Honda.
And it's not going to be a restauration but there is still a lot to do.
- tank needs new coating inside
-there is no speedo
-painting tanks and engine
-new bigger seat
-rearset for braking/shifting
so enough work to do but indeed the base is very good.
I really looking forward to it
Post  andreas on Fri 1 Jan - 0:55
Ok Kornfed - so i will observe you !! Shocked and look what your are doing . Im sure - at the end it will be a great c-racer - like your XS750. It can be also nice to work only "cosmetic" and change the optic direction. So have some fun. BTW - someone take the XS and give you this bike ?
Post  kornfed on Fri 1 Jan - 12:06
Yes Andreas, it was a trade without money. I think the value of both bikes was pretty much the same.
Post  Toecutter on Fri 1 Jan - 17:19
looks very nice man, im looking for a k6 myself. Succes with the build up !
Post  Z666 on Fri 1 Jan - 20:34
you sure got yourself a more valueable bike! nice swap!
Z666
Post  RaceRon on Fri 1 Jan - 20:38
Nice, like the new bike a lot more than the old one, good trade!
Good luck with finetuning it!
RaceRon
Post  650zed on Sat 2 Jan - 12:10
Excellent new project!!!!
Keep us updated!
Post  kornfed on Sat 2 Jan - 16:17
Today for the first time I heard the CB running.
I couldn't get it started so I cleaned the carbs a bit. The needle from the gaschambers was stucked.
After a fiew tries she started and in the neigbourhood was panic allover
What a great and brute sound it makes.
So the first job is to clean the carbs good.
Post  kornfed on Sat 2 Jan - 20:26
So, I cleaned my carbs inside and outside.
Nice result. I won't mount them back yet becauce I want to clean and spray the engine a little bit.
[img][/img][img][/img][img][/img]
Post  Gss on Sat 2 Jan - 21:08
Very good base to start with imo. Very Happy
Good luck with the project and nice start!
Post  Toecutter on Sun 3 Jan - 22:27
How did you cleaned your carbs and wich product did you use ?
Post  kornfed on Mon 4 Jan - 0:38
I have an old ultrasonic cleaner. So I cleaned them with gasoline and wasbenzine??
But the outside have I cleaned with an old toothbrush and wasbenzine. That works almost better as ultasonic cleaning.
There was also some stuff that was hard to remove so I used a schuursponsje met wat CIF.
Gewoon dus ouderwets borstelen en boenen voor het beste resultaat. Very Happy
Post  kornfed on Wed 6 Jan - 19:03
Yesterday I disassembled the frontfork becauce there was no suspension. I ordered new oil and seals. In one of the tubes was no oil at all and it was very dirty. After a few hours cleaning they look better. However the innertube is rusty at the end (where the headlight is mounted) fortunatly is the other side good. For now I have to get on with it.
I polished the outhertube and they look very shiney now. (just used commandant no 4)
By kornfed, shot with FinePix A310 at 2010-01-06
This week I will finish the other fork.
I also bought a nice rearset!
By kornfed at 2010-01-06
Post  Hofman on Thu 14 Jan - 23:11
Cool!
Another CB! Good luch with the rebuild. The tank looks very good. Which brand is it?
Post  kornfed on Thu 14 Jan - 23:40
Hofman wrote:Cool!
It's a Rickman but it is leaking a little bit.
I will try to fix it with epoxy.
A new one is to expensive for me (275 euro in England) so I hope it will work.
Post  Toecutter on Sun 17 Jan - 18:51
okay man bedankt/thanks Very Happy
Post  marc on Wed 20 Jan - 0:52
Mooi project kornfed!! Ben benieuwt wat je daar van gaat maken!!
Leuke basis in ieder geval Cool
Post  kornfed on Wed 20 Jan - 0:58
Dat gaat wel goedkomen.
Vandaag de buitenkant van de tank geschuurd en er een laag epoxy overheen gezet. Ik ben benieuwd of het gaat werken.
Hoe is het met joi project? lang niets van gehoord of gezien.
Post  marc on Wed 20 Jan - 1:02
Ah cool!
Epoxy is ideaal als basisdeklaag!
Te druk helaas! Echt veeeel te weinig tijd!
Hopelijk volgende week uitlaten lassen, accu halen en verder met starten/afstellen :) Electronica is inmiddels wel af!
Post  CJ on Sat 23 Jan - 20:43
Goed bezig.
En nog gelukt met de tank?
Hoe is het trouwens met 'de andere' afgelopen?
Post  kornfed on Sat 23 Jan - 21:16
CJ wrote:Goed bezig.
Ik heb de tank aan de buitenkant in de epoxy gezet. Het is nu net een maanlandschap dus ik denk dat ik het er wat te dik heb opgesmeerd. Maar dat is wel weer mooi glad te schuren.
Ik wilde vandaag eigenlijk de binnekant doen maar het is er nog niet van gekomen. Mede door het koude weer en geen tijd. Even deze week een kachel lenen bij de buren.
Welke bedoel je met de andere? de rode heb ik geruild tegen de CB750 en de groene doe ik natuurlijk nooit meer weg......denk ik Very Happy
gr. Hans
Post  kornfed on Sun 31 Jan - 21:40
Vorige week zondag de binnenkant van de tank behandeld met epoxy.
De tijd zal leren of het werkt.
Vandaag heb ik op ebay nieuwe benzinekraantjes besteld.
Het zijn dezelfde als die er op zaten alleen nu met reservestand.
