Race Diva SR500 project from Andreas
Page 2 of 2 Previous  1, 2
Re: Race Diva SR500 project from Andreas
Post  kornfed on Thu 24 Jun - 17:44
And always online...............
Post  andreas on Thu 24 Jun - 22:26
kornfed wrote:And always online...............
I take the laptop anytime with me - but now i must go to the lathe to make some distance parts for the Thruxton mirrors. I`m back in 10
minutes !
Post  sven on Fri 25 Jun - 16:54
andreas wrote: I`m back in 10 minutes !
Stunden später ... Andy, du hast doch nicht den Futterschlüssel steckenlassen!?
Nice kind of make - tubing instead of sheet alloy as normally used.
I wonder where they're supposed to be fixed to the frame?
Best regards
sven
Post  Toecutter on Fri 25 Jun - 19:31
I figured it out...Andreas is a Robot , he needs no sleep , semi-synthetic oil runs trough his veins and drinks Jet fuel to keep his motor running.
Post  andreas on Sat 26 Jun - 1:09
Best regards
Hi Sven - nein nein, aber es war denn schon Ende des Monats
BTW the rest system looks like this
I`m sure i need shorter legs - but i hope it works for a "icecaferacerround"
Post  andreas on Thu 1 Jul - 22:11
Frame is now painted, first try with the aluparts. This need some work. But at the moment i do some service at a 84 Yamaha XJ900. This is
the nightmare on wheels !! Ok - i do it for money!
Post  andreas on Fri 11 Feb - 18:06
Hi guys, the dark side of winter goes away - THE MOTOR comes back to town - yeah!!. Rebuild SR engine in gunmetalgrey. You never see him before, so look what`s possible. Now i have so much to do - build a bigger showroom, rebuild two SR`s, Thruxtonproject and btw also a 20 years old Vespa ( not really a c-racer) - oh yes i forgot :the rebuild from arround 20 classic steel bicycle. So it`s work enough for two days!!
Post  kornfed on Fri 11 Feb - 21:13
Very nice job Andreas,
Do you still have time to work between the projects?
It looks like your blue SR500.
My xs project is also on a low level I first have to fix a scooter. It's a real troublescooter jocolor
grtz Hans
Post  andreas on Sat 12 Feb - 11:53
Hi Hans,
work between the projects - no, who has time for this? - i take only the money at the end of the month!
The engine optic is not the same - blue Diva is black grey silver. It´s not so clear on the pics, but the gunmetallgrey looks more "technical" on
that motor. I build all my projects in "you will see" construction. So first step is to put the frame on wheels. Possible that i blast the polished parts? - Like i say - you will see construction -
But first - i need space !
Post  Rocker on Sat 12 Feb - 15:38
Hi Andreas
I love what you have done with the engine! Great job!!
Some questions:
did you spray painted the engine? I mean: with a professional spray paint gun?
are those the original side covers, or did you buy new ones?
Keep up the good work!
grtzzz Rocker
Rocker
Post  andreas on Sun 13 Feb - 15:44
Hi Rocker - spraypainted without professionel gun ! Like i do all other paintjobs!. Also the frame is painted with the tin !
And if you know my grey Diva - "tinpainted" .Cover are the old one´s after blasting, grinding and polishing. Not a big job - i show how this works here under "how to prepare old parts".
Post  nlmedic on Thu 24 Feb - 12:11
Hi Andreas,
I salute you..........beautiful as always!
nlmedic
