CB550 Supersport Cafe
Post  schuster666 on Fri 7 May - 14:03
Hey Racers,
hereś my little story about building a cb550 Cafe Racer Very Happy
In December 2009 a bougt a CB550 Supersport 1977 with 37TKM. I wanted exactly that Model cause i saw Cafe Pics before and just fell in love with the CB...
The motor was running quite ok, only the carbs needed to be cleaned and synchronized...
Then i did a few changes to the bike...
- mounted a Raask Rearset
- took of the original rear fender and the taillight
- put on rubber gaitors on the front fork
- cut the front fender
- mounted a racing bar
- took off the ugly plastic box from the cockpit
- build a steel plate with LED light for neutral, oilpressure, direction lights and high beam
The next step was a racing tank and a seat...
from the biginning i knew what kind of tank i wanted for my projekt: a 22l ES Sporttank
and i found one over Ebay...
It was mounted on a Kawa before, so i needed to bulid some clamps to fit on my bike and
weld it onto the tank...
then the tank was sanded and i put on some flaked silver
after the tank fitted to the bike i started to work on the seat. I took my guilliari seat
and cut off 11cm. after that i removed the leather an cut off a bit of foam to make it look
more racing style but still comfortable...
at least a small taillight and number plate holder had to be mounted onto the bike...
Thatś the actual look of my Racer projekt
hope you like it...
schuster666
Re: CB550 Supersport Cafe
Post  Blixa on Fri 7 May - 18:02
Nice project!!
Great that you can build it just as you want it.
One question, how did you convert the Neutral light, high beam, etc. to fit a Led onto it. With power resistors or some another way?
greetings
Blixa
Blixa
Post  schuster666 on Fri 7 May - 18:41
Hey Blixa!
i just threw everything out of the cockpit, cut a plate out of metal and drilled in 4 holes.
Bought 4 LED Lights from a electronic shop and sticked just the right cables together. I bought
special 12V LEDs.
It was pretty easy actually, the only problem was the yellow direction light, because there
are two + cables (right and left side) connected to + of the LED. Needed to use a DIODE for
each + cable.
cheers,
Frank
schuster666
Post  Toecutter on Sun 9 May - 17:03
Nice little cafe, it has some British looks in it. cheers
Post  schuster666 on Mon 10 May - 13:44
...i must have been influenced by the british addiction to soccer
and of course the magic FC St. Pauli in Town
schuster666
Post  schuster666 on Mon 13 Sep - 11:40
just some updated pics with the velocity stacks on...
then i converted the ignition from the cockpit to the frame...
in the next step will convert the elektric under
the seat an get a smaller battery. just like the
look of the frame without the sidecovers
cyclops
greetings,
Schuster
schuster666
Post  caferacer 1975 on Tue 9 Nov - 0:19
i still love those honda's....you can transform them in great looking caferacers...
So looking good!
jocolor
caferacer 1975
Post  MIOB on Tue 9 Nov - 0:21
Are you sure that's the right position for the ignition? Looks to me that the front wheel will sling a lot of dirt in/on it. Looks nice, but I'm not too sure it'll work very long.
Post  schuster666 on Tue 9 Nov - 1:22
@MIOB
Yeah, you are probably right! I changed the position a little. Now it points 45 degrees upwards.
Its now way closer to the horn and not pointing directly to the front tire any more Very Happy
Also got a little 3,2Ah battery. Will put it underneath the back of the seat soon. can't wait to remove
the side covers. I really love the pure look of the frame
Twisted Evil
cheers,
Schuster
schuster666
Post  rice.desert on Tue 14 Dec - 19:07
those velocity stacks are bad ass where did you get them?? I wanna put some on my cb
rice.desert
Post  schuster666 on Thu 23 Dec - 16:35
@rice.desert
i was lucky to get them via *bay for real cheap
good Luck!
Schuster
schuster666
