JABSA Engine
JABSA Engine
Post  tdl1325 on Sun 15 Jan - 1:04
Finally finished the JABSA engine, will try it in the frame soon.
90.5mm bore, 88mm stroke, GM conrod, B31 crank modified to DB 32 Goldstar spec, JAWA 894 barrel and DOHC 4 valve head.
tdl1325
Re: JABSA Engine
Post  joolzned on Mon 20 Aug - 12:05
interesting combination I would imagine it should produce plenty of power
Engine check
Post  tdl1325 on Mon 27 Aug - 23:34
Engine has done about 200 miles now so timing cover removed to check all is OK. Oil changed and cam chain adjusted. Timing cover and chest inspected, no problems, nice and clean inside. Engine is lively up to 4000rpm when it just takes off like a rocket! Probably a combination of the speedway high lift cams and the electronic ignition getting to full advance. It does 95mph in third gear at about 7500rpm and I would imagine 50 BHP , maybe more is a realistic output. Must get it onto a dyno soon.
tdl1325
Re: JABSA Engine
