Harley Norton project ...
Page 2 of 4 Previous  1, 2, 3, 4  Next
Re: Harley Norton project ...
Post  Crazy Cavan on Fri 2 Jan - 22:09
potverdikkie maar dat ziet der goed uit zeg!
Post  pitte on Sat 3 Jan - 1:25
zoooooooowwwwwwwwwwwwwwww das zeer mooi kwijl kwijl kwijl
zie ik daar soms op de achtergrond een T500 blokje???
pitte
Post  harton on Sat 3 Jan - 1:51
pitte wrote:zoooooooowwwwwwwwwwwwwwww das zeer mooi kwijl kwijl kwijl
Heb wel t500 maar het blokje rechts onder op de foto is een ´68 Kawasaki A7 350. (roterende inlaten)
harton
Post  Crazy Cavan on Sat 3 Jan - 2:05
vind die rachts boven veul interesanter, als ik het goed heb is dat een van de eerste sportster blokken Very Happy
Post  harton on Sat 3 Jan - 11:43
Yep !
harton
Post  marc on Sat 3 Jan - 14:12
gaaaaaaf!!!
Volgens mij heb jij nog veel meer mooi spul thuis staan Razz
Die harton word schitterend Cool
Post  andreas on Fri 9 Jan - 13:22
He Mister Harton
please it will be wunderfull if you write in english - it will be very interesting to share your work with other guys - no matter if anything is correct. English is also not my favorite - but i hope all members understand what i want to say.
So feel pity for us "outernetherlands"
Post  650zed on Fri 9 Jan - 13:43
andreas wrote:please it will be wunderfull if you write in english - i will be very interesting to share your work with other guys - no matter if anything is correct. English is also not my favorite - but i hope all members understand what i want to say.
Yep, I agree.
Nobody has to write in English, of course - everyone is free - but it's much nicer for the members from outside Holland! We have now members from Belgium, France, Germany, Finland, Austria, Italy, America, Mexico, Indonesia, Australia, etc. It would be cool for them to participate to all forums and to be able to use all the information we post here. After all, the objective of this forum is to be international.
Cafe Racers of all countries: Unite!
Post  harton on Fri 9 Jan - 19:25
Yep, I agree.
Ok, message is clear, English only if possible.
Deutsch would not be the biggest problem, aber für die Ausländer (und natürlich Ausländerinnen) ist english besser.. scratch
harton
Post  650zed on Fri 9 Jan - 19:52
harton wrote:Ok, message is clear, English only if possible. scratch
Nice one. As said earlier: you don't HAVE to do it, it's up to you. But if you do, it's nice for the others.
Post  andreas on Fri 9 Jan - 20:42
Yep, I agree.
Thanks HARTON - nice that you go with us. I shiver if i see your project - so i will know what you are doing on this bike
oncemore Thanks!!
Post  harton on Sat 10 Jan - 11:58
Hi Guys, did my best to translate it as request.
Thanks...
harton
Post  harton on Sat 10 Jan - 11:59
harton wrote:Some updates of the project.
At this moment the bike is complete taken apart.
Frame and some other smal parts are sandblasted at the painter right now, also the cam and sprocket cover, these also be black.
I polished al aloy parts, rebuild the forks with new stanchions, progr. springs, bushings and seals. I made new header pipes, took a pair of new jawa 2-stroke pipes have them un-chromed and cut them in about 6 pieces to re-weld them in the headers to fit. Have them re-chromed together with other smal parts.
I decided to paint the brake plates black, maybe it would have bin nice if i had done the hub also
Also adjusted the brake so it is ready to fit and go.( I machined the brake surfaces in the hub after it was spoked by Haan wheels, only this way the brake wil be at his best as the hub is mostly not round after rebuild. Ofcourse is has new linings, also machined for exact fitting)
I definitly wanted to fit a SMITHS magnetic racing tacho as i think it´s the best looking tacho around. This tacho was used on many racer of the fifties and sixties.
As these original tachos are rare and prices go over €600 i dicided to build it myself.
Machined a housing , This tacho should be cable driven original but i used the electronics from a used harley tacho as this is more acurate and easy to fit to the crane hi-4 ignition used. The dail i luckely found on ebay once, it is a original piece from a manx ATRC. Glas and bezel are new. Was a lot of work but it was worth it, just as the original. Think i will combine it with a chronometric Speedometer.
Have the engine covers back from painting so i can close the engine. I´m very happy with the result as i did not want the engine have to much polished and chrome parts.
To be continued, Erik
harton
Post  650zed on Sat 10 Jan - 13:41
Post  Hofman on Sat 10 Jan - 23:03
It is an amasing bike!
Didn't know that a Harley engine was so beautiful for a caferacer.
And the sound would be great I guess Very Happy
Are you doing any modifications on the engine itself? More horsepower maybe?
Post  andreas on Sun 11 Jan - 14:33
Hi "Mister Harton" - thausend "THANKS" for translate. Respect in what you do - for me a secret is what you do with the Smiths chronos. I never will open a thing like that oncemore. But if you need really professional help ( also replacement parts) look for the small German company is called "KAYA TACHODIENST". I give an old SR500 speedo for repair - and this is more a "once use" thing. Perfect work and exellent rebuild ! In Germany they are the best choise, if you have any trouble with Speedos an some more.
I hope one day we get a "youtube" sound,vibration and rollout view on you project.
Post  harton on Sun 11 Jan - 14:49
Hofman wrote:It is an amasing bike!
Thanks, any mods? scratch think i did enough to make it a non-standard ironhead engine.
sounds like your not familiar with harley engines Wink . Original engine has single carb in the middle and both exhausts on the right side, The dry belt Primary drive and clutch mechanisme are not standard, original it´s a closed oil filled tripple chain primary. HP ? Possible it will have some extra´s hp from original but don´t expect spectacular figures.
harton
Post  harton on Sun 11 Jan - 15:29
Did some cosmetic on the primary side of the engine, clutch-actuator and inside of case painted black.Ignition timing-marks are made on the outside of the engine ( front pulley ) for easy timing.
Clutch is converted into 6 springs instead of the 2 big ones, keeps it more straight wenn pulled.Clutch mechanisme has a bearing to support the clutch on the outside.
Still have to make a cover for the generator and a front pulley protection.
Frame back from painting, rebuild can begin Very Happy
Front engine mount with regulator fitted.
harton
Post  Riko on Sun 11 Jan - 15:53
The sheer number of engines in the background utterly scares me. So does the craftmanship with which you build your bike. I'm very curious to see how the bike will be once completed and I won't post any pictures of my own project since utter shame has come over me.
Keep up the good work!
Riko
Harley KH900 engine
Post  TinTin on Wed 21 Jan - 15:34
if you ever want to part with the KH engine..... i've got a KH900 '56 in my garage but the engine needs a rebuild. Would be easier to buy yours and exchange them drunken
Post  harton on Fri 23 Jan - 10:14
TinTin wrote:if you ever want to part with the KH engine..... i've got a KH900 '56 in my garage but the engine needs a rebuild. Would be easier to buy yours and exchange them drunken
Mine is a ´55, This engine will not help you, I bought it in a box complete taken apart, still need some parts for it and then full rebuild Very Happy
Put together bare cases and cylinders for display so i can look at this great engine a lot, if my wife would not be against it it was standing in the livingroom .
harton
Post  harton on Fri 23 Jan - 10:30
Got the engine in the frame finally, just forgot how i got it out so got it in half from the wrong side 1st time! What a heavy lump this engine is.
Always a fucking job to get a engine in without damage the paintjob of the frame
harton
Post  650zed on Fri 23 Jan - 11:08
harton wrote:Always a fucking job to get a engine in without damage the paintjob of the frame
I can imagine...
It's beautiful, anyway!
Post  harton on Sun 15 Mar - 18:56
Time for a update, Bike could be finished by now but i recieved the keys of my new house so have something else to do now Sad .
Good thing is i will get 250 m² of garage there and can get all my bikes, parts, machines, tools etc. with me at home as it al is at my parents house right now.
At this moment it looks like this,
Recieved the new seat yesterday, nice work done for a good price. ( Kees van Hoof, Nuenen. http://www.keesvanhoof.nl/index.html )
Making the headlight/ tacho-speedo mounting now, finding the right place for these is important to give a bike the right looks.
Also decided to mount the steel fork shrouds instead of the rubber ones.
Complete electric still has to be done, It has umbilical cord only to run it right now!
harton
Post  Toecutter on Sun 15 Mar - 19:03
Oh what a beauty f*cken hell !!
