Grey Diva SR500 project from Andreas
Page 3 of 4 Previous  1, 2, 3, 4  Next
Re: Grey Diva SR500 project from Andreas
Post  andreas on Wed 23 Dec - 22:16
TinTin wrote:I probably need a bit of sandblasting work done next year on the frame(bits) of Morini 3 1/2... 150 euro seems a reasonable price if you're not too far away in Germany... what's your ZIP code?
Hi Tin Tin, zip code is 29499 Zernien. From Germany the cheapest way is over DPD, cause they don`s ask for the weight - only 300cm strapmessure arround is the limit.
Post  TinTin on Wed 23 Dec - 22:40
Zernien is about 4 1/2 hours driving... I'll inform with DPD what the rate is...
Post  TinTin on Wed 23 Dec - 22:46
quick quote from the Dutch DPD site:
There's nothing easier. Parcel shipping with DPD.
Shipping parcels with DPD is very simple, but there are just a few things for you to take care of. Your parcel should be packed correctly for transport and be suitable for processing on automatic sorting conveyors. This also means:
your parcel can weigh up to 31.5 kg
the combined dimensions (longest side + circumference) can be max. 300 cm.
the max. length can be 175 cm (longest side).
I wonder if I can squeeze a Morini frame in a 31.5kg 300cm circumference package... I'll get back to you
Post  andreas on Thu 24 Dec - 12:42
Hi Tin Tin - if i send it from Germany - they have no weight limit - only these 300cm arround. So i wait for you.
Please accept that it need some time to arrange the coating - 2 or 3 weeks is normal. If you have more parts in the same colour - at the end it`s cheaper per part. I can sandblast smaller parts before, and tape the critical points. For sending : ask a bicycledealer for a transportbox. Very often you can get a perfect box there.
Post  jfg75 on Fri 25 Dec - 3:44
Im considering a similar project. Really nice work. Definitely in the details!
jfg75
Post  sven on Mon 1 Mar - 2:02
andreas wrote:
Very nice work at the lathe, Andy!
Awesome combination of grey, alu and stainless steel!
If I can help you with remachining VA-bolts let me know.
Best regards
sven
Post  andreas on Mon 1 Mar - 20:24
Hi Sven, thanks for the "flowers" - nice to hear that from a "drillingmaster" . I come back to your offer for the screws - at the moment i have no chance to get my bikes out of the garage. Snow, snow, snow and once again sh.... snow - i hate frozen water!!!!.
Post  sven on Mon 1 Mar - 21:57
So bad with the snow?
Here close to the alps it's +10C and no cloud is to be seen!
All the fucking snow melted!
Best regards
sven
Post  andreas on Sun 28 Mar - 12:22
And here also - paint some parts in " Absynth green metallic" with high gloss finish. I will check it on the bike. At the moment the motor is complet strip down to messure all parts. But with all work on the old machine i need some weeks.
Post  kornfed on Sun 28 Mar - 14:06
I like your style Andreas.
Keep up the good work.
grtzz Hans
Post  kornfed on Sun 28 Mar - 14:08
BTW..
Did you have a look on this site?
http://www.short-cut.nl/
I think you might like it too.
Post  andreas on Sun 28 Mar - 18:41
Hi Kornfed, thanks for this ! No - i never see this site before. My first thought was " looks like BRATSTYLE" and some minutes later i saw they visit them in Japan. Nice rides - for me a bit to dark and a copy from Bratstyle - but who care`s ?? Cool bikes ! Otherwise it is not so easy to find your own style - hope one day someone say - oh, look this is a bike from "retrospeedstyle61"" - okay, i know this is a long way if it`s not your "first" job every day.
But, any way starts with the first step.
Post  andreas on Sat 1 May - 16:14
Update - rebuild brake caliper - before and now - ready for mount on.
Post  650zed on Mon 3 May - 10:17
andreas wrote:Update - rebuild brake caliper - before and now - ready for mount on.
So, this one is now, right? :
Post  andreas on Mon 3 May - 12:01
Exactly!! classic retro rebuild - not so easy to paint in black/white with that used look - but you see - no problem for me! Who likes a green perfect finished caliper ?
Post  650zed on Mon 3 May - 15:37
Post  Toecutter on Mon 3 May - 21:13
lol funny guys eyyy! i like it retro too jocolor
(nice job btw)
Post  andreas on Fri 18 Jun - 23:13
The old motor needs a longer rebuild "timeframe". So i buy another one, clean it and saw that some aluscrews are corrode. So i must take apart
the head, bullsh... So i will take a look inside, and rebuild what`s necessary. This will be fixed at the end of the month.
I will paint it in black and try the sidecovers in "absynthgreen" - hope it works
Post  andreas on Sat 5 Mar - 15:36
Check a new seat for the grey Diva - Motor is also near "ready to go". So much things to do - next weeks my clubroom project starts - if the
snow goes.
No time for sleeping in the next 8 months!
RS61
Post  Luckyboy on Mon 21 Mar - 1:53
Reputation well established,
oooh I like the seat..
Well done Andrea.
Luckyboy
Post  650zed on Mon 21 Mar - 14:19
Post  kornfed on Mon 21 Mar - 14:59
Very nice work Andreas.
What kind of brakediscs you have used and are they also availeble for a XS750?
Or maybe you have an adress for nice brakediscs.
grtzz Hans
Post  andreas on Mon 21 Mar - 20:01
Hi Kornfed,
the disc is personal made !! If you need a fixed one, i need only diameter and can ask if you can get a pair - or maybe one. Price is arround 120,- per piece. I can send them to you.
Post  kornfed on Mon 21 Mar - 20:52
As far as I know they are the same as on your SR but I'm not sure.
Do you have a detailed pic of the disc?
Post  andreas on Mon 21 Mar - 22:42
Here it is.
